ATF? - WTF!
lowey
Wed Nov 04, 2009 3:52 pm
Strange experience with ATF...
Went out to my SPORT, been stood for 2 and a half weeks, started her up and the gearbox light stayed on. Reversed her out the garage, very clunky (!) so drove her back in and checked the ATF dipstick - NOWT!! Garage floor bone dry....
BUT, went out to the garage 3 hours later, dipstick shows FULL!! Is this normal? If the car stands a while does the ATF drain where dipstick can't read?
Am I going nuts? :? :? :? :? :? :? :?
Or did one of you sneak into my garage while I was listening to Steve Wright and put 3L of ATF in my car?
(p.s. love the show)
B4UR
Wed Nov 04, 2009 5:43 pm
That is very strange :?
nicey
Wed Nov 04, 2009 8:58 pm
You should check the atf level once the car car has been driven 10 miles or so, then on flat ground with gearbox in park and engine running. :cool:
ProToZyKo
Thu Nov 05, 2009 2:56 pm
When cold it will show more on the stick.
Start the car put it in each gear for a few seconds, then check the stick, and refill if needed.
I usually drive a little after to make sure it takes all that it need then recheck the stick.
Dazdabomb
Thu Nov 05, 2009 8:26 pm
ProToZyKo wrote:When cold it will show more on the stick.
check with car in neutral while the engine is running
