What management is it using? I know nothing of sequential setups and their software, but if you can find out what it is, usually it is downloadable.
Then try and find the comm port and plug a laptop in too check for any error codes etc. Once you have the software open you should be able to see it live in action and using the Lambda sensor tell if it is running too rich on different loads. Annoyingly it is a narrow band I suspect, but it should give you the right idea if it flicking between rich and lean like it should.
Interestingly if you fancy a drive to Salisbury one evening/weekend me and my brother have got a wideband lambda sensor with a bungied exhaust probe for on the road testing in different cars.
/Cough\Pikey/Cough\ This is the best way of working out what actual AFRs you have. I am not sure what AFRs LPG should run on, I am presuming it is roughly the same as a petrol-so around 12.5-13.5:1
