UK e36 m3 forums?
Coldaccord
Post Mon Oct 26, 2009 12:09 am
I have a euro s50b30 in my e30 and stateside, these aren't too common. I was wondering if there were any uk e36 m3 forums. Always good for parts, info, etc. thanks
eko
Old timer
Post Mon Oct 26, 2009 12:15 am
www.e36coupe.com is the only one I know of.
Post Mon Oct 26, 2009 12:19 am
there are a number of S50 swapped e30's on here.. So there is knowledge on here also :wink:
Coldaccord
Post Mon Oct 26, 2009 12:37 am
already found my first bit of useful info on here
old_skool wrote: Next for the coolant sensor. I had no idea this had to be done, thanks again buster for the heads up. I didn't know this but for the E30tem,p gauge to work the S50 has to be fitted with the M20 coolant sensor. Again, BMW have been kind enough to leave a spare port for it to go in:
Blank hex plug to right of S50 coolant sensor:
M20 brown coolant sensor and spare plug:
The Brown/violet wire on pin 1 of the S50 sensor needs to be pulled out and connected to the M20 sensor:
Sensor fitted:
8)
now hopefully I can get my temp gauge to work.
