m50 oil cooler
bumhole
Post Sun Oct 25, 2009 12:25 am
Hi everybody!
I've been trailing through many previous topics but can't find one on fitting the m20 oil cooler to your newly fitted m50! just wondering if it is possible and if it is worth it??
Only reason I ask is because on a recent track day, the m5o was running sweet until a few too many laps thrashing it, the temp guage would start to creep up pretty high and on the way in to the pitts there was a very loud horrible sounding tappy noise. I imagine I have cooked the oil and lost oil pressure to at least one of the tappets? After a cool down it would run perfect again until a few too many laps thrashing it, the same would happen agian! I keep meaning to ask opie oil man if there is a better oil that will stand the thrashing! I'm using fuchs at the minute but its only semi synthetic.
Any help much appreciated, and if it is possible and worth it, where do you stick the pipes?
Jody
benjy
Post Sun Oct 25, 2009 12:45 am
It has been done, by Ste IIRC. Have a search on here and also try e3024v forum ;)
Gaffa tape is like "the force" - it has a light side, a dark side, and it holds the universe together.
There's nothing that shouts "Poor Workmanship" more than wrinkles in the Gaffer tap
Post Sun Oct 25, 2009 1:06 am
Better oil..
Post Sun Oct 25, 2009 10:10 am
You dont need an oil cooler, but if you decide to fit one you will either have to fit M3 housing/alternator/pas pump or buy a kit from the states that replaces the filter housing cap
bumhole
Post Sun Oct 25, 2009 1:05 pm
Cool, thanks. Won't bother then!
I'll get some better oil.
rix313
Post Thu Nov 12, 2009 1:01 pm
Speak to Guy at Opie oils he'll be able to give you some good advice on which one to get and you'll also get a discount for being a zone member.
