will the [m30] 3.5L 12 v engine fit in any e30 shell [is the 316 smaller than the 320+ ?] WITH ROOM for added holset hx40 turbo, intercoooler, megasquirt ecu, and what power can i expect at what boost?
or should i fit the 2.8 24v e36 motor and do the same?
costs, pro's and con's ?
i was also thinking about the 4.4L v8 or the 5.0 v12 with this setup. what about space in the engine bay?
what costs are the 3.6 and 3.8L 24v m5 engines + g'box?
what are costs for 3.0 and 3.2L e36 engines+ g'box?
should i use a 5 series instead for bigger engine bay space, and how much weight kg would i save over using an e30 3series the same age 5 series?
sure this has been asked much but any specific replys appreciated
