Hi car failed the dreaded MOT today on following
001 nearside rear brake pipe corroded
002 nearside rear parking brake recording little/no effort
003 nearside rear brake juddering severely
004 parking brake effiency below requirement
Any ideas and tips on doing the jobs would be helpful. 320i Touring btw
Brake Help Needed
Nobby_N
Do not take anything i say seriously as i am a bit of a cnut!
Nobby_N
discs buddy, going to change them tomorrow if i can get hold of any.
reddrifter
probably needs new handbrake cable but worth doing both, obv discs, and brake pipes are piece of cake, if you have a pipe flaring kit to manufacture them as dont think you can get pre-made, to be fair, i only ever wire brush the od one and cover with grease then it should pass if corrosion no longer visable, its 9 times outta 10 surface corrosion anyway
