and are they suppose to move up and down about 2cm ???
other side moves up and down 1cm
are these knackerd????
and are they easy to replace?
Or the more sensible option if you plan keeping the car, would be a pr of alloy rose jointed ones from GazImysE30 wrote:Get E46 cab replacement one's Alex
I just feel, that if you plan keeping the car for several years then the initial cost of the uprated topmounts are offset by not having to replace standard ones more frequently.OK there will come a time when you have to change the R/J but it shouldn't be as often as replacing OE E30/E46 mounts.gooner1 wrote:Dave, why do you say more sensible option![]()
I ask as i was planning to upgrade to the E46 ones on my cab.
E46 cab ones are a straight swap.N00b wrote:Are the e46/Gaz parts a straight swap?
Any particular e46 cab or are they all the same?
Those are the one's I was going to mention,but I couldn't remember who made themMorat wrote:I've got the Rogue Engineering top mounts. Pricey at £70 a pair from Evo-S but they are really solid items.
LINKY
