E36 323i gearbox?
eko
Old timer
Post Wed Sep 09, 2009 10:50 am
Need to replace a whining gearbox in a mates 95 323i.
Anyone know if the box from a 320 or 325 is a direct swap ie propshaft guibo size?
Dont want to get the wrong one only to find out the original prop doesnt fit.
noble-tech1
Post Wed Sep 09, 2009 11:33 am
i was told the engines the same as a 325i but i mite be wrong, any1?
Post Wed Sep 09, 2009 12:32 pm
I am pretty sure the box is the same as the 320i and 325i
StuBeeDoo
Post Wed Sep 09, 2009 2:18 pm
Try asking on E36Coupe forum.
Post Wed Sep 09, 2009 7:31 pm
325i and 525i ZF box's will work, not 100% sure on the 320 box but it has to be a ZF if it does fit
Do you want to buy one? :)
eko
Old timer
Post Wed Sep 09, 2009 8:22 pm
DanThe wrote:325i and 525i ZF box's will work, not 100% sure on the 320 box but it has to be a ZF if it does fit
Got one in the garage but will have to check which it is first.
Price on yours incase?? :wink:
Ant
Retired Team Member
Retired Team Member
Post Wed Sep 09, 2009 8:51 pm
use ETK Tony, look up the prop guibo and clutch and check for parts useage, takes all the guesswork out but I'm 99% she'll bolt up no issues.
