Half Cage
sebring
Fri Sep 04, 2009 1:10 am
Non sunroof 2 door.
What options / prices / where from ?
UweM3
Fri Sep 04, 2009 8:31 am
why half?
sebring
Fri Sep 04, 2009 9:25 am
Car is to be used for road and track and therefore I do not want the front intrusion. In addition I do not want to wear a helmet everywhere I go in case of collision ! (Don't want to crack your head on a cage - possible even with harnesses).
rix313
Fri Sep 04, 2009 1:46 pm
You looking for a bolt or weld in?
Where're you located?
sebring
Fri Sep 04, 2009 5:27 pm
Bolt in preferably. I'm based in Essex.
basky
Mon Sep 07, 2009 10:50 pm
i could make you a bolt in one powder coated to wot ever colour
with removable braces :D but would need the car
Mon Sep 07, 2009 11:27 pm
Where are you Basky?
basky
Mon Sep 07, 2009 11:29 pm
staffordshire
Jim78
Tue Sep 08, 2009 8:31 pm
Roughly what sort of price is one of these bolt-in cages out of interest Basky?
basky
Tue Sep 08, 2009 11:19 pm
from about 150 depending on finish and cross bracing etc
but a std 1 brace half cage painted about 150 ish powder coating a little more
theres all sorts of extras removable cross section,gussets full x bars and harness bars etc
this only a hobby by the way,will be at the pod come have a look,only doin a half cage at the mo in mine as wont have time to take the dash out,
zaust
Zone day release
Thu Sep 10, 2009 11:31 am
Half is just dangerous. If you stack there is a good chance of your head comming off worse due the car strengening point's being moved. Don't do it, full or nothing.
M30 Tech 1 Touring on gas.
basky
Thu Sep 10, 2009 8:03 pm
done properly they should pick up on existing seat belt fixings
on the latter part of the hoop to stop that from accuring
but deffo fro track or race then full cage
UweM3
Thu Sep 10, 2009 9:13 pm
basky wrote:from about 150 depending on finish and cross bracing etc
just out of curiosity, what material are you using? Are you able to bend the tubes yourself? 150 is not a lot IMHO.
mattrs
Thu Sep 10, 2009 9:17 pm
No its cheap, how much for a full cage? how much fitted too?
basky
Thu Sep 10, 2009 10:38 pm
150 would be for a std half cage with single cross bar.
the tube is 42mm o/d (not cds tube)the price would be alot more using cds
UweM3
Thu Sep 10, 2009 11:57 pm
basky wrote:150 would be for a std half cage with single cross bar.
I was wondering if you use CDS for that sort of money. But anything less than CDS is a waste of money IMHO. You can buy a "core kit" pre bent and just fabricate the straigh tbits yourself.
basky
Fri Sep 11, 2009 12:14 am
i have the use of a pipe bender that pulls the pipe through aswell as bends at the same time giving perfect bends to any angle,we do 3mm s/s handrail 50 mm o/d so 42 cds would not be a problem
most omp or saftey devices ar,nt cds (the cheap one,s anyway)
did a cage for a friend with a cossied up morris minor out of cds,more of a space frame really and the tube was expensive then.that was a full cage and cross brace and harness bars straight through to the suspension turrets.
UweM3
Fri Sep 11, 2009 9:31 am
you are aware off that FIA regualtions do ask for CDS?
your bender, ist it a crush bender or mandrel?
RPM
Fri Sep 11, 2009 10:19 am
UweM3 wrote:you are aware off that FIA regualtions do ask for CDS??
As is the MSA requirement in the Blue Book
driftmonkey
Fri Sep 11, 2009 5:19 pm
was that cossie morris for a guy called mike haslemere way?
if so he mentioned to you to be about doing a cage for me, if its you pm me and we can talk details
basky
Fri Sep 11, 2009 7:49 pm
its the mandrel one.
people are takin this to far,i never said iwas doing the cages to msa or fia regs.
no the bloke with moggy is rob slater.his minor has done 11,1 sec quaters running his gas this year.
UweM3
Fri Sep 11, 2009 8:50 pm
basky wrote:its the mandrel one.
mandrel bender, nice one! If I would have access to a mandrel bender I would be banned from the work shop :D :D :D
M3GTR
Fri Sep 11, 2009 9:37 pm
Where in Staffordshire are you Basky? I'm in Stone (between Stafford and Stoke)
basky
Fri Sep 11, 2009 11:05 pm
i work in stone,live in caverswall
M3GTR
Sat Sep 12, 2009 9:21 am
Extraweld by any chance then? Those guys did some bits for me a while back!
basky
Sat Sep 12, 2009 6:47 pm
yep..
GeoffBob
Forced Induction Specialist
Mon Sep 14, 2009 3:00 pm
Basky, not to criticise (and I accept your comment about not building to meet FIA requirements) but if you have access to a mandrel bender then you have the means to build a top-notch cage using CDS. Non-seamless has an awful habit of splitting open along the seam in the event of an impact, and can thus cause severe injuries. For a bit extra (and peace of mind), CDS is the way to go.
UweM3
Mon Sep 14, 2009 8:44 pm
GeoffBob wrote:Basky, not to criticise (and I accept your comment about not building to meet FIA requirements) but if you have access to a mandrel bender then you have the means to build a top-notch cage using CDS. Non-seamless has an awful habit of splitting open along the seam in the event of an impact, and can thus cause severe injuries. For a bit extra (and peace of mind), CDS is the way to go.
and lets not forget the weight saving. But price difference of CDS is quite significant compared to ERW. Another obstacle is the minimun order you have to put down to get some CDS in the first place for a reasonable price. Not many stockists will sell you just a length or two.
basky
Sun Sep 27, 2009 8:36 pm
yes your all right on the cds tube,
but with it being the first cage for an e30 it would be better for me to do it out of erw as i got loads of it available and free.the cds will be along later when mods and alterations are made.
as for the cds we order that much steel i could get it at a good price i would of thought(but its not quite free)
