Converting from tech1 to tech2
e30briyan
Mon Aug 17, 2009 2:26 am
looking to ocnvert my early chromie to tech2 spec, i know i have to change the fron panel for the later ones, do i specifically need a cabby panel or will the saloon/coupe panel fit? same goes for the tech2 bumpers aswell? also what do i have to do to fit the rear bumper? any tips ony converting or links to threads would be appreciated
cheers
SeymourCake
Mon Aug 17, 2009 2:39 am
Check out my thread mate...
Should tell you what you need to know
mrLEE30
Mon Aug 17, 2009 11:49 am
all is covered here.
http://www.r3vlimited.com/tech/bumper/bumper1.htm
the only main difference is you will not need to modify the length of the rear bumper as shown in the article.
This is because the tin tops have a different rear wheel arch profile between pre and post face lift (to allow more legroom in the rear seat apparently??), but as far as i know the cabs all had the later rear wheel arch profile irregardless of the cab model thus the tech 2 should fit on, however the mods to the front metal valance and mounts still are the same as Jordan's article.
mrlee
