M50 Out.... M50 in!!!
Daf318is
Post Tue Aug 11, 2009 10:56 pm
As some of you are aware I've been having some bother with my M50. It sounded like a bag of spanners, it burned more oil than petrol, and lost water out of every possible place! So....
Out came the offending engine
Interestingly water came out of one of the exhaust ports as it was being pulled :eek:
The new cylinder head I spent the last few evenings on lapping all the valves in (M20 does have an advantage here!!)
Nicely honed out block with new rings :D bearings were very good so they stayed in and saved me a few £££s!
Who needs the expensive BMW tool to time up a twin cam engine! winkeye
The bare replacement engine! Waiting to go in!
I thought I'd break out the marrigolds and clean up the turd of a rocker cover whilst it was appart! :gay:
Freshly painted!
Back on the road :D
It runs! Woohoo! - It ran like poo to start with - 'till i noticed I had left the ICV off, M50s don't work well without an ICV :o: ! I've done a whole 30 miles in it and it appears to be fine (touch wood!) although I had a moment of idle hunting and kangarooing - hopefully this is just a teething problem though! - Watch this space :D
Now driving an E46 320D touring :(, but it get's worse..... the new project is going to be Ford powered!
E30Gheko
Post Tue Aug 11, 2009 11:12 pm
:drool: lookin very nice Daf! U'll have to pop over and show it off! winkeye
Pal318is
Post Wed Aug 12, 2009 1:59 am
You made that look so easy 8O
Looks spot on :cool:
Pal
Image[img]http://Image
Daf318is
Post Wed Aug 12, 2009 12:47 pm
Pal318is wrote:You made that look so easy 8O
It was winkeye there was no swearing, cursing, spanner rash or anything :D
toby
Post Wed Aug 12, 2009 3:30 pm
Nothing wrong with a bit of marigold action (better than a skin disease or rashes).
That looks to be have been very satisfying work, good work man! I really like your improved special tool there. I saw it posted the other day on another thread.
Have you got a thread of your original build? I would like to see the spec, what gearbox you used etc.
Daf318is
Post Wed Aug 12, 2009 3:37 pm
toby wrote:Nothing wrong with a bit of marigold action (better than a skin disease or rashes).
Don't actually have an original build thread - I just posted up a few pictures now and then :)!
I used an M42 box as the car used to be an IS (until I saw sense winkeye ) what else did you want to know! :D
toby
Post Wed Aug 12, 2009 4:00 pm
Thanks for offering to share info. I'm not doing this conversion myself yet but I'm just interested. I'm thinking that the 318is is a good basis for M50/M52 conversion.
So just M42 out M50 in?
Prop the same?
Change the diff to another ratio, if so which one do you choose?
Daf318is
Post Wed Aug 12, 2009 4:06 pm
No I used a 325 prop and you need to chop up the gear linkage because the engine sits further back.
I changed the diff for a 3.73, this gives nice driveable gearing :)
Manifold is the biggest farce 8O but there is plenty of info on this in the epic M50 conversion thread :)
rix313
Post Wed Aug 12, 2009 5:40 pm
Got a picture of the engine bay? :D
Don't pull anothe iS apart :(
Daf318is
Post Wed Aug 12, 2009 5:52 pm
rix313 wrote:Don't pull anothe iS apart :(
It's not like I fragged the sacred IS! I just did what BMW should have done from the factory - they put the right number of valves per cylinder but the wrong number of cylinders winkeye !
toby
Post Wed Aug 12, 2009 7:38 pm
Daf318is wrote:No I used a 325 prop and you need to chop up the gear linkage because the engine sits further back.
Yes and it's great to see a simple list of what you used in your car.
A nice M50 article for the zone wiki would be good with the essence of the combinations of parts listed and examples.
Would also make a good TBMW article. Say four or five M50 vehicles, each using a different method for the conversion. The variations might depend on what engine the vehicle ran originally dictates the method of conversion. Plenty of people would buy that issue I'd like to think.
no1_jazz
Post Wed Aug 12, 2009 7:48 pm
that must be fuin to drive wiv all that power hey 8)
