For a 1987 325i manual.
(Full set of all of these)
New valves
Valve seals
The little cones (there's two halfs for each valve, cant remeber their name)
Valve guides
Double Springs and the little disks that go above and below them
Gaskets (bar the head gasket)
All studs (bolts?) that stick out the cylinder head
New spray bar and bolts
Pully (and all parts that connect the pully to the head).
Anything else I may have missed.
If you could break down the parts and prices for the above that would be great, cheers.
Cylinder head parts. 325i
Nay
- Channel Island Crew
Uni is killing the project.
Nay
Ok, I'll get them this way. Ignore the previous post!
Can you please work your way through this as its quite a lot. Should all be for an earlier engined 325i.
http://www.realoem.com/bmw/showparts.do ... g=11&fg=15
Parts: 1, 3
Parts: 1, 2, 3, 4
Parts: Everything, except cylinder head and head gasket.
http://www.realoem.com/bmw/showparts.do ... g=11&fg=25
Parts: Complete Set of - 8, 9, 10, 11, 14, 15, 16, 17, 18, 19, 20, 21 (12 of each?)
Parts: 4, 5, 6, 7, 8
If you could break this down into the sections so I dont get lost reading through all the parts I would be extremely grateful
Thank you very much in advance!!! Sorry for consuming so much of your time
Parts: 1, 3
Parts: 1, 2, 3, 4
Nay
Please.....?
Cotswoldbmw
Hi there
sorry for the delay can you PM your email
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
