fuel pump q
slideways
Post Tue Aug 02, 2005 6:30 pm
is the fuel pump for a (90) 325 sport in the tank. was under the impression it was.
mate asked me had i a pump.
i have a pre face lift 325i broken.. lifted the seat but it doesn't look like there is a pump there..
trotter
Post Tue Aug 02, 2005 10:29 pm
E30 1970 TO 1980
CARS WITH -
BOSCH K-JETRONIC FUEL SYSTEM
ON ALL ELECTRIC PUMP (FUEL INJECTION) EQUIPPED CARS,THE FUEL PUMP IS MOUNTED TOGETHER WITH THE EXPANSION TANK FOR THE EVAPORATIVE EMISSIONS CONTROL SYSTEM.
THE PUMPS WHICH ARE MOUNTED TOGETHER WITH THE EXPANSION TANK ARE LOCATED UNDER THE REAR OF THE CAR.
BE SURE TO DISCONNECT THE BATTERY BEFORE WORKING ON THE FUEL SYSTEM.
GARY
johnl320
Look under the car about ten inches in front of the rear left wheel,i think you'll find the pump is there.
Regards
john
Templ8e30
Post Wed Aug 03, 2005 7:45 pm
trotter wrote:E30 1970 TO 1980
????? E30's were made between 1982 and 1993 surely ?.
The pump is under the black metal cover under the back seat (drivers side) and is fitted into the top of the fuel tank.
Cheers,
Iain T
2007 Mazda 6 2.0 estate
Turbo-Brown
Boost Junkie
Post Wed Aug 03, 2005 9:10 pm
Tis definately just infront of the NSR wheel on my 1985 car.
Spotted it rusting away under there the other day :)
Taylor325i
Location: Kilmarnock, Ayrshire, Scotland. Brilliant Red Tech II 325i.
Post Wed Aug 03, 2005 10:01 pm
Turbo-Brown wrote:Tis definately just infront of the NSR wheel on my 1985 car.
Could that be the fuel filter perchance ???
Taylor.
johnl320
Cheers,
Iain T
not on an old skool mate :cool:
john
GDBN
Post Wed Aug 03, 2005 11:25 pm
Same with my 86 cab ...just in front of the left rear wheel ...fuel filter under the bonnet .. under the brake servo
Post Thu Aug 04, 2005 12:50 am
GDBN wrote:Same with my 86 cab ...just in front of the left rear wheel ...fuel filter under the bonnet .. under the brake servo
IIRC, the pump under the wheel arch is the high pressure pump. There's still a pump in the tank that feeds the other pump.
Jos
Post Thu Aug 04, 2005 2:39 pm
The prefacelifts came with a sender pump intank and a high pressure pump mounted infront of the rear offside wheel. The post '87 cars had this changed to a single high pressure intank pump.
'94 e36 tree climber
