Can't Start, Won't Start!!!!
Kedge
Post Thu Jan 27, 2005 4:43 pm
Basically the car fires up when i turn the key and then just dies straight away. Got no idea why its just happened, not had any problems with it at all and had been running fine earlier today.
At least i was at home when i did it!
Any Ideas?
Instagram - Kedge85
A1BMW325iSport
Post Thu Jan 27, 2005 6:39 pm
sounds like fuel pump relay dead, or the 12v switched from ignition not getting to it.
Post Thu Jan 27, 2005 6:53 pm
First check. Connect a small 12V lamp between the + terminal of the ignition coil and body of the car. Should light when ignition turned on, stay on, slightly dimmer while the starter is operating, and still stay on after you release the key. If it doesn't then ignition switch is faulty.
Second check - Connect your test lamp between fuel pump feed and body. Lamp should light for a few seconds when ignition turned on, then go out. Should come back on when the starter operated and stay on with the engine running. If engine stops it should go out again. You can get at the fuel pump wire (green/violet) by pulling off the boot of the c101 connector on the bulkhead.
Post Thu Jan 27, 2005 6:55 pm
Meant to add , usually pin 13 on the C101.
Kedge
Post Thu Jan 27, 2005 7:01 pm
Cheers for the advice will try those tests in the morning, would i be able to do it on a multi meter?
Instagram - Kedge85
A1BMW325iSport
Post Thu Jan 27, 2005 7:25 pm
yes multimeter same, its just to check you have voltage on those connections.
Gwynleym10
Post Thu Jan 27, 2005 7:32 pm
Also check for Vacuum leeks especially in the air intake bellow, mine had the exact same symptons as that, and it had a masssive crack un the uderside of the bellow (after the afm)
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
