rear wheel camber, adjustments
nigel79
Post Thu Jan 27, 2005 12:39 pm
hi am putting coil overs on my car, but unsure whether the back will suffer from to much negative camber. do they, if lowered to much, will be running 17s. also just wondering if any of the racers have seen or converted there rear end to adjustable set up, ie rose joints. the car is mainly going to be used for track days at the moment. and making parts isnt a problem as im an engineer. any help or pictures would be cool. thanks have the rear arms off at the moment as changing to rear disc set up.
Karan
Post Thu Jan 27, 2005 4:24 pm
yes u will have probs with neg camber for sure!
one thing u can do is change the trailing arm bushes for eccentric ones.
search 'ireland engineering' on google and look at their site- they do them there, u should be able to fit them easily, they just need tack welding in place i think, to stop em spinnin round
Karan
nigel79
Post Thu Jan 27, 2005 11:59 pm
thanks for info. forgot to say, i have no rear anti roll bar fitted yet. will this make a difference to the wheel camber.
Karan
Post Fri Jan 28, 2005 12:07 am
that will not affect the wheel camber but will greatly improve handling and reduce body roll
