I need Info please!!
Belzabub
Post Tue Jul 14, 2009 9:07 pm
:evil: HELP!!! I own an E36 M reg B,M,W 1.6is, and my baby E30 G reg 1.8is. Well the G reg has developed a nasty tick, and the lowest quote ive had to fix her is £800. And my M reg needs over £1000 to get it back on the road. So i had a brain wave about swoping the engines. So i keep my beloved E30 but i get a relyable engine. But i need to know if its A, an easy job? and B, if so what needs to be changed...... Please can anybody help???
toby
Post Wed Jul 15, 2009 12:59 am
I haven't seen many (if any) of these swaps done on this forum but think I've seen it on http://www.m42club.com/forums/index.php
Belzabub
Post Wed Jul 15, 2009 2:17 pm
brill, thank you. i take a look. fingers crossed
Post Wed Jul 15, 2009 3:18 pm
so you want to put an m40 or m43 what ever it is into your IS 8O
what exactly needs doing?????
Belzabub
Post Wed Jul 15, 2009 3:21 pm
I got an E36, that the body is totaled on, but the engine and gearbox are sound. and i have an E30 where the body is sound, but the engine has developed a nasty tick. the cheepest quote ive had to fix the tick is £800. if i swap engines its must work out a hell of alot cheeper... you see where im aiming??
**BANNED**
Post Wed Jul 15, 2009 5:48 pm
A few points worth considering.
The engine in the E36 will not be a direct fit,the sump will foul the E30 crossmember.
Once you have overcome this,with the related oil pump pick up issues involved,you will have to consider engine management issues.
After you have solved this,you will have to sort an exhaust manifold/downpipe.
Might just be easier to sort your ticking engine..... winkeye
Youth is wasted on the young.
oakey
Post Wed Jul 15, 2009 5:49 pm
Would be easier to fit another e30 318is engine imo
Belzabub
Post Wed Jul 15, 2009 6:20 pm
:cry: oh right. Damn it!!!! oh well thanks for your help guy's. was just hoping i could get it sorted on the cheep. oh well back to the dilemer of which car do i keep.
Post Wed Jul 15, 2009 11:22 pm
Belzabub wrote:. oh well back to the dilemer of which car do i keep.
That, at least, is an easy question to answer! One is verging on becoming a classic, while the other will only ever be baked bean tin raw material.
n1tr0_9
Post Wed Jul 15, 2009 11:24 pm
You should be able to get a decent E30 is engine off the zone for less than £250, i did! Make sure you see and hear it run before handing over the cash though.
toby
Post Thu Jul 16, 2009 12:39 pm
Ok what is the tick in the E30 engine then and what costs £800? :)
