i have recently noticed that my leccy fan (91/99degC-but set to 91) has started coming in about 3mm further up the stock e30 gauge than it normally does (usually comes in just above half, noc coming in just below 3/4 of course this is still within normal limits howveer it worries me in traffic.....
now do u reckon this is down to the bmw brown temp sensor playing up there for it appearing to come in later but actually still coming in at normal actual temp..... or my switch for my leccy fan in the rad which is only a few yrs old playing up and coming in later than usual...
in any case i have fited a bypass switch just in case to turn my leccy fan on if needs be or for some doughnut/burnout action
Karan
water temp sensor issue
Karan
Andy325i
Have you had this setup working Karan? (Brown temp sender and 91/99c Thermo switch?) I have this one mine, guess ur using the E36 switch?
Mine also comes in about 3/4 up the scale, so like you I just have an overide switch.
My conclusion was that the 24valvers run hotter?
Andy
Andy
Karan
yeh ive always had it working......Andy325i wrote:Have you had this setup working Karan? (Brown temp sender and 91/99c Thermo switch?) I have this one mine, guess ur using the E36 switch?
Andy
just used to come on lower down the scale before.....
i have a feed into the sensor in rad then 2 outpts currenlty only one is in use-91degC as i only have a one speed fan whereas i believe some M3s had 2 speeds with the faster coming on at 99degC
Andy325i
Dam! There goes my theroy then!
Back to the drawing board!
Let me know when you slove it mate
Andy
Andy
Karan
does ures acrually come on though at 91?Andy325i wrote:Dam! There goes my theroy then!
Andy
Andy325i
never measured the temp (any idea how?) just comes in way too hot for my liking (3/4 up the scale)
Andy
Andy
ian332isport
Karan,
The only way to know if the problem is the radiator temp switch or the temp gauge (brown) sender, is to measure the temperature of the radiator itself. I have a temp probe for my multimeter for this, but not sure how you could do it without. When I installed an electric fan on Paul (Shinobi1's) car, I did measure the radiator temperature, and the switch did seem to be quite accurate.
As for Andy's problem, he may need to get a lower temp radiator switch. You can get an 80/88 degree switch under part number 61 31 8 361 787. This is a direct replacement for the 91/99 switch. For the record, I'm using the lower temp switch on my conversion, but have it wired for dual speed operation because of the aircon install.
Cheers,
Ian.
Cheers,
Ian.
Karan
Ian.... do u remember which one u put in my car? how much is this switch roughly then? ill try measuring somehow the temp but my multimeter doesnt have a probe... i guess some kind of thermometer will do LOLian332isport wrote:Karan,
Cheers,
Ian.
cheers
Karan
ian332isport
Hi Karan,Karan wrote: Ian.... do u remember which one u put in my car? how much is this switch roughly then? ill try measuring somehow the temp but my multimeter doesnt have a probe... i guess some kind of thermometer will do LOL
cheers
Karan
I don't recall which one we fitted to your car. Ste bought the switch, and I fitted it. They sell for about Ԛ£24, so not cheap for what it is
I guess any sort of thermometer that can be touched against the radiator fin's would work. My temp probe fit's snugly between the fin's, and gives a pretty accurate reading.
Ian.
Andy325i
Cheers,
Ian.
