virgin on tour
thekingofswing
Wed Jun 17, 2009 11:09 pm
HELLO PEOPLE I AM LOOKING FOR SOME ADVICE IM THINKING OF BUYING A 325I TOURING A DECENT FAMILY CAR AND SOMETHING I CAN HAVE SOME FUN WITH AT THE WEEKEND.. THE QUESTION IS SHOULD I AVOID A PARTICULAR YEAR OR IS THERE AN ENGINE I SHOULD STEAR CLEAR OF AS IM A VIRGIN ANY GUIDANCE WOULD BE GREAT THANKS :? :? :?
Last edited by thekingofswing on Wed Jun 17, 2009 11:26 pm, edited 1 time in total.
skipunda
Wed Jun 17, 2009 11:12 pm
they all have their good points. be wary of quite a few e30's claiming to be more than they really are.
and please lose the full caps
Chris
tinnaM42
Wed Jun 17, 2009 11:14 pm
ther's a real good toutring for sale on here 1000 smackers nice example :D
Cook318IS
You won't be a virgin for much longer once your "broken in" for using caps lock 8O :chuckle:
Cotty
Hartge Crew
Wed Jun 17, 2009 11:17 pm
No major problems with a 325i as long as it has been looked after, check the history services, when the cam belts have been changed etc
The touring has handy carrying capacity.
& lose the full caps
thekingofswing
Wed Jun 17, 2009 11:24 pm
Didnt realise it was a crime to use caps lock :mad: dont know much about the e30s ive been told that a 325i puts out around170bhp as standard if this is the case would it take much to get it up arond the 200 mark winkeye
tinnaM42
Wed Jun 17, 2009 11:36 pm
u'd need to spend some serious money to get 200bhp out of the the 2.5 lump it 's already been tuned to it's fullest really by bmw
thekingofswing
Wed Jun 17, 2009 11:45 pm
fair enough my last whip was a 3litre v6 vauxhall omega which ran over 200 as standard are there any mods that are worth doing or is it not worth the hasle...
Cook318IS
Wed Jun 17, 2009 11:49 pm
if you want to run 200bhp. the cheapest way is to fit the m50 or m52 from the e36/e34. At 192bhp for a 2.5 its not half bad. A bit of fannying around is needed for some parts to make it fit. If you're interested in the swap there is a thread at the top of the engine swaps / forced induction forum bit with the title of something like "Considering an m50? read this..." or something like that
Thu Jun 18, 2009 12:14 am
One point to consider, if you are going to do the very worthwhile conversion of fitting a M50 engine, is that if the touring you buy was first registered after 01/08/1992, then you will have to fit the M50 with a cat, or run it on LPG, to realistically pass a UK MOT test.
If you are prepared to do the engine swap, and are happy to run with a cat, then the best choice of touring would be a very late 316 lux, as they were made for a year or so after 325 production finished.
Nay
Channel Island Crew
Channel Island Crew
Thu Jun 18, 2009 1:58 pm
These cars just wont have 170bhp anymore. If you spend serious money you may get it back up to there with replacing worn stuff in your engine.
All sorts like camshafts and big bore thottle bodies etc can produce a bit more power, but they have some potential, but not much. The tuning mods often make the car more responsive or quicker to accelerate etc.
Common things in these cars is to do mods that improve upon stock parts such as uprating the steering rack, or putting (as above) bigger/newer engines into them...
A nice 325i is a lovely motor though, and a bit of tweeking might not make it incredibly rapid, but a hoot of a machine! Best thing to do with these is to replace worn parts and give them some of their original flare back.
BTW, 200bhp + is entirely possible. Just be prepared to pay a lot of money! Camshafts and kit, Wild/Custom ECU, Big Bore Throttle Body, maybe a 2.8L conversion, BTB exhaust manifold, ported and polished heads and so on, incuded with a nice rebuild of most other engine parts (the worn stuff) to their former glory and you should hit that mark and maybe some more. Turbos or Superchargers can add a serious amount for the nutters who are willing to do what it takes to fit them!
Uni is killing the project.
Thu Jun 18, 2009 2:15 pm
tinnaM42 wrote:u'd need to spend some serious money to get 200bhp out of the the 2.5 lump it 's already been tuned to it's fullest really by bmw
Bollocks it has.. 68bhp/l is a mild state of tune
thekingofswing
Fri Jun 19, 2009 10:27 pm
thanks for the advice i will bear this all in mind on reflection i probably wont go for the 200bhp mark but if i do you will hear about it winkeye winkeye winkeye
HairyScreech
Sat Jun 20, 2009 1:14 am
one thing to remember is the v6 omega is a much heavyer car.
Sat Jun 20, 2009 1:56 am
buy spadges,ex spooks 325i tourer,
sure you'll be fine.
http://www.e30zone.net/modules.php?name ... c&t=138257
bargain 8)
