inspection 2
mabz
Post Sun Jun 07, 2009 1:56 pm
i just got a e36 compact as a daily whilst my e30 is off the road.im thinking of getting an inspection2 done on it soon.is there anywhere on the net where i can find a list of all the stuff they cover and replace parts/oils etc any help would be appreciated thanks
320ise
Post Sun Jun 07, 2009 2:12 pm
i want this aswell please. did have it bookmarked but have lost it lol
Post Sun Jun 07, 2009 3:00 pm
from the old zone
BMW DEALERSHIP MAINTENANCE OIL SERVICE
Engine Compartment:
Ӣ Change oil and oil filter
Ӣ Check coolant level
Ӣ Check steering fluid level
Ӣ Check brake/clutch fluid level
Ӣ Check windshield washer fluid level
Ӣ Check ATF fluid level (if equipped)
Undercarriage:
Ӣ Check steering box and steering linkages for leaks and excess play.
Ӣ Inspect brake callipers, discs and brake pad thickness.
Ӣ Inspect brake hoses and lines for damage or leaks.
Ӣ Check handbrake, adjust cable if needed.
Ӣ Check and adjust tyre pressures.
Ӣ Check spare tyre pressure.
Body and Interior:
”¢ Check operation of exterior/interior lights (including glove box, engine compartment”¦ )
Ӣ Check headlight aiming.
Ӣ Check condition and function of seat belts.
Ӣ Check operation of washer system.
Ӣ Check wiper blades condition.
Road Test:
Ӣ Check brake performance.
Ӣ Check heating/ventilation.
BMW DEALERSHIP MAINTENANCE INSPECTION 1
Engine Compartment:
Ӣ Check and adjust valve clearance (M20)
Ӣ Change oil and oil filter.
Ӣ Check battery acid level and correct if needed.
Ӣ Check coolant level and inspect system for leaks.
Ӣ Check steering fluid and brake/clutch fluid level.
Ӣ Check windshield washer fluid level.
Ӣ Check ATF fluid and LAD level (if equipped).
Ӣ Lubricate throttle linkage
Undercarriage:
Ӣ Check transmission for external leaks.
Ӣ Check manual transmission level, add if needed.
Ӣ Check final drive fluid level, add if needed.
Ӣ Check fuel lines, fuel tank and all connections for leaks.
Ӣ Inspect exhaust system.
Ӣ Inspect front suspension and wheel bearings for play.
Ӣ Inspect wheels, tyres and adjust tyre pressures.
Body and Interior:
Ӣ Lubricate door hinges, hood latch and bonnet hinges.
”¢ Check operation of exterior/interior lights (including glove box, engine compartment”¦ ).
Ӣ Check active check control panel for faults.
Ӣ Check function of air conditioning. Check refrigerant charge at sight glass.
Ӣ Tighten A/C compressor mounting bolts.
Ӣ Tighten nuts and bolts for door locks and striker plates.
Ӣ Replace intake dust/pollen micro filter in A/C unit.
Ӣ Replace batteries for alarm/remote control in master key (if equipped).
Road Test:
Ӣ Check braking performance, steering, HVAC, transmission and mirrors.
This article is copy write to E30zone and must not be replicated without prior permission.
BMW DEALERSHIP MAINTENANCE INSPECTION 2
Engine Compartment:
Ӣ Check and adjust valve clearance (M20).
Ӣ Replace camshaft timing belt every other Inspection 2 or 50K miles.
Ӣ Inspect V-belt/Poly-ribbed drive condition, check tension (M20).
Ӣ Lubricate throttle linkage.
Ӣ Change Oil and oil filter.
Ӣ Change air filter or clean it if reusable (like K&N).
Ӣ Check Coolant level and inspect system for leaks.
Ӣ Check Steering fluid and brake/clutch level.
Undercarriage:
Ӣ Change automatic transmission fluid.
Ӣ Change manual transmission oil.
Ӣ Check clutch plate for wear.
Ӣ Check drive axle boots for leaks.
”¢ Change final drive fluid (’95 change synthetic fluid every other Insp.II).
Ӣ Replace fuel filter.
Ӣ Check thickness of parking brake linings.
Body and Interior:
Ӣ Lubricate door hinges, bonnet latch and bonnet hinges.
Ӣ Check operation of washer system and wiper blade condition.
”¢ Replace batteries for alarm/remote control in master key (’95 E34).
Road Test:
