Prop shaft damper.
stratos
Post Mon Jun 01, 2009 9:54 pm
Has anyone had any experience in removing the damper fitted at the forward end of the propshaft ( surrounding the Guibo)?
I am trying to save weight wherever I can and this is quite a hefty rotating item.
If I remove it will I get some bad vibes ?
318 is.
Black_Potato
Post Mon Jun 01, 2009 10:44 pm
You'd want to get the prop shaft proffesionally balanced after.
Chris-W
Post Mon Jun 01, 2009 10:52 pm
Fit a new prop to 'box guibo and omit the damper, it'll be fine.
