Hi chaps,
Does anyone have any experience on adjusting the bite point on a 325i? It bites really high. It's had a new clutch and master cylinder
I've read that there is adjustment above the pedal. How effective is this?
Clutch bite point
Demlotcrew
There is A small adjuster on the pedal, if you look at the bolt that connects the pedal to the master cylinder, its eccentric so you can turn that, but it at best will move the pedal by about 1cm.
Andrew
Andrew
