OMP roll cage - anyone have one fitted?
moggy
Thu May 21, 2009 10:49 pm
Hi
We have just purchased this - should arrive tomorrow.
It's for our 4 door 325. Does anyone have one fitted? I would like to see some pics / experiences of fitting.
rosscoe
Fri May 22, 2009 11:28 am
Which one is it???
106Aw by any chance?
alan1272
Fri May 22, 2009 2:19 pm
here's my omp 6-point, was a bit of a mare to fit although i have seen another type of omp 6-point with a bolted front hoop that looked a damn sight easier to fit.
as you can see i had to fabricate boxes for it to sit on.
moggy
Fri May 22, 2009 4:02 pm
rosscoe wrote:Which one is it???
I think it is 104P? or 100?? It's a bolt in 6pt
mike_sayer
Fri May 22, 2009 4:12 pm
We have this cage - couple of not very helpful pics on our thread below. I'll try and take some better shots showing the installation for you. Fitting wasn't too bad...
http://www.e30zone.net/modules.php?name ... ic&t=94931
"And if you are clinically insane, by which I mean you wake up in the morning and think you are an onion, here's your car." - Clarkson
moggy
Fri May 22, 2009 4:33 pm
Edit - just confirmed it is a 104p.
It has the roll hoops as described.
Thank you for the pics. We are getting someone to fit this as to conform to FIA it needs mounting plates installed and neither of us can weld.
How long would you expect someone to fit this given they haven't fitted one to an e30 before, the car has the dash in, one FIA seat in easily removeable and I know there are some rust issues in the footwell (although the fabricated boxes are a good idea).
My best guess is two days labour?
Unless someone volunteers to fit it...
Mike - some pics of the mounting points would be great :)
moggy
Fri May 22, 2009 5:38 pm
Roll cage has just turned up - some pics of it here...
http://www.photobox.co.uk/album/112058385
fieldl
Fri May 22, 2009 6:14 pm
What sort of bolts do people recommend fitting these with? and which washers too I guess.
M8 ISO grade 8.8 - Any ideas on ideal length? and whats the ISO thing all about then ?
rix313
Fri May 22, 2009 7:46 pm
Hex head bolts are fine. 8.8 is the general standard of most bolts sort of the best alrounder.
It goes up 9.8 10.8 12.9 and goes down 5.8 5.6 4.8 4.6 3.6.
Table here shows their tensile strengths etc: http://www.roymech.co.uk/Useful_Tables/ ... rength.htm
It's to do with the strength and quality of the bolt. Mines held together with 8.8's iirc. Not sure on the length, easy to work out though, just measure the width of the tube + 2 standard washers + nylock + a little bit more to make sure the nylock is properly on.
moggy
Tue May 26, 2009 10:05 am
alan1272 wrote:here's my omp 6-point, was a bit of a mare to fit although i have seen another type of omp 6-point with a bolted front hoop that looked a damn sight easier to fit.
Alan - did you have to fabricate boxes because you are tall and needed height above the drivers helmet (as per MSA spec) or because if you didn't the cage would sit lower than the height of the door frame?
alan1272
Tue May 26, 2009 8:19 pm
i made them because it would sit too low otherwise. i only know of one other omp cage that has had this issue, all the rest i've seen seem to meet the floor.
moggy
Wed May 27, 2009 11:55 am
Sit too low because of you being too high or the door frame being too high?
JimmyC
Wed May 27, 2009 3:58 pm
Its not a sunroof cage is it ie fits with the sunroof in place, as in lower in the car?
alan1272
Wed May 27, 2009 11:15 pm
no, i have had it in a facelift and pre-facelift(current) cars and when the cage was jacked up to be tight with the roof the feet sat like this:
first i thought it was the wrong cage but i wasn't a massive fuss to make some boxes from 3mm steel plate with captive nuts.
it's all possibly a bit irrelivant to anyone but me as i know of only one other omp cage like mine, all others seem to clear the dash rather than go through it and the main hoop goes all the way to the floor.
i assume mine was measured up on a sunday morning by someone suffering the effects of a heavy saturday night :wink:
moggy
Thu May 28, 2009 12:00 am
Thanks for this info Alan :D
3mm thck steel passes MSA regs I presume?
We have 3mm spare alu - does anyone know if you layer the alu it can get past the regs?
JimmyC
Thu May 28, 2009 10:10 am
What series are you building it for?
JimmyC
Thu May 28, 2009 1:04 pm
Have you entered any TTRS rounds yet?
moggy
Thu May 28, 2009 2:30 pm
No - see above, the car is currently without roll cage.
TTRS is probably the least favoured of the 4.
JimmyC
Thu May 28, 2009 3:11 pm
moggy wrote:No - see above, the car is currently without roll cage.
Sorry I meant for later in the year :)
Why's that? Genuinely interested as one of the organisers
Its about half the price, its at all the big circuits, strict driving standards, close racing and in my bias opinion has the best socials ;)
Also you get to support the PBMW races, e30 overload!!
moggy
Thu May 28, 2009 3:53 pm
It isn't as local for us.
It isn't as cheap as some of the competition above.
It appears more strict -some of the regs seem a bit anal - why not just set the standard to the blue book?
Honest feedback :)
JimmyC
Thu May 28, 2009 4:03 pm
Location- we hit the big circuits and don't focus on one area- so yes some will require travel
£100 per race, £200 for 2 not sure who's competing with that? And looking at the above links I cant see anything close :?
Anything above the bluebook is only to further increase the safety of our drivers, something which comes from PBMW roots. And any restrictions are to keep the racing affordable for our drivers.
We have 4 325's currently registered so you'd be in good company :)
Thanks for the feedback :)
