hi I slammed the glove box shut and it is now stuck lol. are there any tricks to getting into the glove box ?
Regards
James
stuck glove box
- **BANNED**
Glovebox mounts on a bracket held by two 8mm self tappers.Pull the carpet back in the footwell to find them.With them out it may be possible to 'wiggle' the thing free,or get your fingers inside from behind to squeeze the lock fingers in.
Youth is wasted on the young.
beemerbird
Sounds like it might be worth trying your key in the lock? Assuming the glove box uses the same key as your ingnition....
rubber_duck89
just been out to mine and it does. try tapping it with a small hammer that worked for minebeemerbird wrote:Sounds like it might be worth trying your key in the lock? Assuming the glove box uses the same key as your ingnition....
