Uprate clutch for m20/s50 b32
dicko
Post Tue May 12, 2009 4:17 pm
I am fitting a m20 fly wheel on my s50 b32 where is the best place to get a clutch to take the extra grunt ,will be fitting a zf 5 speed out of a 525i sport , will a need to play around with release bearings to get it to work .
I may be doing some other mods to the s50 later so if i can find a clutch that was a little room for more power all the better .
The car will be used for mostly road use and the odd track day .
If any of ye m20 turbo lads can advise me it would be much apperciated .
UweM3
Post Tue May 12, 2009 5:41 pm
If you just buy a light flywheel from TTV you can use the stock clutch and release bearing.
£220-230ish for the flywheel.
dicko
Post Wed May 13, 2009 10:38 pm
dont have the stock clutch iam affraid
UweM3
Post Wed May 13, 2009 11:19 pm
dicko wrote:dont have the stock clutch iam affraid
you lost me there. You asked where to get a clutch, so I assumed you haven't got one. To keep things simple I suggested to use a flywheel which allows you to use a stock clutch with stock release bearing. What have I missed?
dicko
Post Thu May 14, 2009 7:50 pm
the S50 came with no flywheel and no clutch , so I was hoping to use a my M20 flywheel and uprated clutch to suit .
I will buy a new soild flywheel and clutch ( I dont like dual mass flywheels ) if I have to
rob_htid
Post Thu May 14, 2009 8:11 pm
if you do use a standard or lightend m20 flywheel i have a brandnew sachs clutch kit for £80 delived wich will be fine
or if you are planning on big power and want the best go for a 6paddle heilx but they are £500
