Post
Tue May 12, 2009 3:51 pm
Hi James,
I've already done this calculation for someone else to day, so I might as well do it for you while I still have the spreadsheet open.
With your Getrag-260 gearbox, the proposed 3.73:1 differential, and a pair of 215/40/16 rear tyres, your road speed at 6500RPM will be:
31mph in 1st gear,
54mph in 2nd gear,
84mph in 3rd gear,
118mph in 4th gear, and
146mph in 5th gear (if you have the power to make it here. Sorry, but I don't know what mods you have made to your engine. I suspect that you may find your top speed around 130mph at 5500rpm in 5th gear with this diff).
Most importantly, since this is a part-time track car, if you shift up a gear at 6500 rpm your revs will drop to:
3734RPM from 1st to 2nd,
4136RPM from 2nd to 3rd,
4643RPM from 3rd to 4th, and
5265RPM from 4th to 5th.
Alternatively, to land your revs on exactly 4500 rpm after a shift up you will need to rev to:
7900RPM in 1st gear (37mph, hmmmmm?),
7100RPM in 2nd gear (59mph),
6300RPM in 3rd gear (82mph), and
5550RPM in 4th gear (101mph).
At 70mph on the motorway in 5th gear your revs will be exactly 3100RPM.
I could be wrong but I suspect that, with this diff, this will amount to a 4-speed track car, with a 5th gear for off the track. If intended for use purely as a track car I would not recommend you use this diff, but you should still be able to have a lot of fun with it using 1st to 4th on the track, with a nice 5th for on the motorway. Note that, given that you are not running the most powerful engine amongst the E30's, you will likely see your acceleration times most notably compromised in 3rd and 4th gear compared to your old diff, but I don't think this should deter you.
Regards
Geoff
EDIT: Values have been updated to reflect the tyre size shown below.
