best suited subwoofer/amp for a cab? as there's limited space?
are there any enclosure pics upon the zone?
sub
RICKESH
Here's my effort, doesn't leave much boot space though
1000W RMS DB Audio sub powered by a Vibe Slick A3 amp:
paulmitchell1984
i recone witht the right subs, you could get 2 x 10" in a decent enclosure under the hood (on a manual roof), just need to measure up work out how much room you would have with the cubic feet then source the subs, then get an amp to drive them
its something il be looking into eventually
It was what i was going to do first, 2 x 10" subs fit near enough perfectly under the hood compartment but changed my mind
I've got measurments for a sub enclosure somewhere, i'll see if i can find them
mrLEE30
single 12 inch with loads of room, amp mounted as you can see. easy to remove incase of flat tyre, 3 cubic feet internal volume with a port firing to the side you cannot see.
power taken from the rear demister heater supply from behind rear seat. for more info just ask!!
