Rear tyre wear...
bazman
Mon Apr 13, 2009 11:26 am
Hi all,
looking for a bit of advice. I am in the process of replacing the rear shocks on the touring, I was checking out the brakes etc and I noticed the inner edge of both rear tyres (and the spare, so its obviosuly been happening a while prior to me buying it, oops) is worn right down, while the outer edge has little wear and the tread is generally pretty good across the rest of the tyres. Anything glaringly obvious I should look at replacing before I bung new rubber on please? Mot is looming too...
Thanks in advance.
"Build a man a fire, and he'll be warm for a day. Set a man on fire, and he'll be warm for the rest of his life." - Terry Pratchett.
leeparkes
Mon Apr 13, 2009 11:28 am
Is it lowered?
fuzzy
He who sleeps with "Gingers"
Mon Apr 13, 2009 11:32 am
my -40 at the rear doesnt cause excessive wear like that.
Security2U
Mon Apr 13, 2009 11:33 am
My rear tyres are wearin on the side aswel. :x :cry:
leeparkes
mine did at 60mm but at 40mm its not too bad.
cass1_5503
Mon Apr 13, 2009 11:43 am
my car eats tyres on the 60mm drop its not uncomon for a pair of tyres to only last 3-4 thousand miles
leeparkes
Mon Apr 13, 2009 12:01 pm
is it similar to this :)
The_Diddler
Love it up the more door !
Mon Apr 13, 2009 12:03 pm
leeparkes wrote:is it similar to this :)
:rofl: :rofl:
Bob_S
Mon Apr 13, 2009 12:34 pm
my 35mm drop will eat tyres.. but it's the way i drive
Bollocks to this 24v scrap!
bazman
Mon Apr 13, 2009 1:04 pm
Its not lowered as far as I can tell....but it does have the E30 wear pattern!! :mad:
I am guessing this is normal?? :roll: Any other ideas or is it a case of it is what it is?
Cheers!
Bob_S
Mon Apr 13, 2009 1:29 pm
it is what it is unless your trailing arms are bent
hammoj28
Mon Apr 13, 2009 1:42 pm
Mine wears more on the inside at the rear on a 35 drop.........
24v tech2
