It always fires up on first twist of the key, but takes (feels like an eternity) probably a second or two before it rumbles into life.
Recently changed which may help you identify the problem are:
Alternator including brushes
Dizzy cap and rotor arm
Assuming that the brown plug next to the blue one is something to do with the Brown Temp sensor, the brown plug has been replaced as the wires were ripped out by a heavy handed partner. Not with an OEM part, however.
Once the engine has warmed up, only the slightest cough is heard prior to it doing what it's supposed to do.
Any advice or suggestion would be, as always, gratefully appreciated.
Fi
