Head Unit in the center console
pegase747
Hi to all,
has anyone tried to install the head unit into the center console ? I mean horizontally, just below the HVAC panel.
I am thinking about doing that to put some VDO gauges in the original radio location.
I basically just like to know if there is enough space there, because I am pretty sure it will be wide enough.
hope anybody can help.
Regards / Pierre
Regards / Pierre
maxfield
I doubt there will be enough space as there's a heater matrix and transmission tunnel there...
pegase747
horizontally above the tunnel ???? Dont know about the heater matrix though....
Anybody got a pic of a 30 interior witht he center console removed ??
Pierre
Pierre
Eddie25
springer
Hi early last year i fitted a Dvd player in the centre console it is tight but can be done
maxfield
You can just see the heater matrix...
miniblob
You mean behind the ashtray, right at the bottom of the centre console?? Easy peasy!!
I've had a full size (single din) digital eq in there before!!
Just took out the bottom centre console thingy, used a stanley knife to cut the hole out, fitted the cage and slotted it in!! There was plenty of room for wires - i had at least four sets of phono's and the usual power/ground/illumination and i'm pretty sure i squeezed a plg1 line driver in there too!!
Not sure how hot it would get in there, but it can't be any worse than the standard position - if anything, there is more scope for the heat to rise away for the unit - and i suppose you could always drill some small vent holes in the sides of that panel, that would hardly notice!!
Short answer: Yes
Short answer: Yes
327 Touring with bass!!!
pegase747
HGi Springer,springer wrote:Hi early last year i fitted a Dvd player in the centre console it is tight but can be done
would u have a picture of your setup ?
Pierre
pegase747
Miniblob any pics ?miniblob wrote:You mean behind the ashtray, right at the bottom of the centre console?? Easy peasy!!
Short answer: Yes
pierre
cass1_5503
i have got a single din dvd in there and also my ipod adapter is there. quite abit of room there to be honest.
cass1_5503
heres a pic i just found of mine
pegase747
Thanks,
was it exactly the same length/depth as a standard head unit ??
Cheers / Pierre
Cheers / Pierre
cass1_5503
yeah it was
E30_Jatt
cass I've just been looking at that pic of your install and was thinking to myself something seems odd, out of place, and I've just realised now what it is. It's the fact that your OBC/Clock and your stereo are the opposite way round to any normal UK spec car, how did you achieve this? because it's not a LHD dash as then it would be angled towards the left for a LHD car.
I think it's quite cool how the OBC is just at finger length and easy to access then when your driving.
cass1_5503
it was actually quite easy its just the heater panel from a lhd car, the finish aint the best but with a little work should look goodE30_Jatt wrote:cass I've just been looking at that pic of your install and was thinking to myself something seems odd, out of place, and I've just realised now what it is. It's the fact that your OBC/Clock and your stereo are the opposite way round to any normal UK spec car, how did you achieve this? because it's not a LHD dash as then it would be angled towards the left for a LHD car.
fowler
- Boost Junkie
it can be done i have also had a single DIN DVD player in this space. fits nicely
Heat in this area is less than in the standard position for the stereo.
you can actually fit a DIN size stereo and a 1/2 DIN equaliser in this postion but with both units wiring gets a tad tight
EX A-Tech Workshop bitch !!!
gone but not forgotten
pegase747
Hi Fowler,
Do you have a picture of your setup ?
Also Do you have aircond fitted ? I heard that the space behind the console is less on cars with aircond...
Cheers / pierre
Cheers / pierre
fowler
- Boost Junkie
no i don't mate sold the car a couple of years back.
IF aircon is fitted forget about it mate TBH
just take out ashtry and put VDO guages there
