318is - water pump failure?
Nizzle
Post Fri Jul 15, 2005 10:49 am
Hi all,
Been looking at this site for a while and finally decided to join in the fun :D
The car goes into a garage on Tuesday, but any thoughts advice in the meantime would be appreciated.
I have a 1990 E30 318is, with 148,000 or so under it's wheels. It's a top car that looks better on the inside than on the (pinkish red) outside! It's got FSH, but I admit that I've been neglectful and have been putting up with a noisy fan belt for the last few weeks...
Well, a couple of days ago I was driving down the road when the battery charging light came on, along the the handbrake and brake warning lights (I think). There was also a very loud squealing noise from under the bonnet. I stopped the car, considered my options (am I fu** going to walk home!) and started the car again. It ran ok and I got home.
I got the bonnet up and I can see that with the engine running, the shaft that the viscous fan is connected to is actually moving up/down, and left/right 8O sounds like some bearings have broken up in there - am I right in saying that the shaft leads back into the water pump?
Also, the reason that the charging light came on is that sometimes, again while the engine is running, the alternator and water pump (both driven by the same belt from the crank pulley) stop rotating. Yes, scary.... I suspect that it's the water pump (or whatever the fan is connected to) that is stopping the alternator, not vice versa. Anyway, enough of the message/vent/cry, I would appreciate any thoughts you might have, cheers!
Geeman
Post Fri Jul 15, 2005 10:58 am
Yup... water pump dude.
Not a bad job to replace really... radiator out, then it makes access easier. Might as well replace the thermostat while you're at it as it'll only take a few minutes to take the housing off while everything else is off...
Hope that sorts your problem!
Giles.
Nizzle
Post Fri Jul 15, 2005 11:35 am
Cheers for the quick reply Giles :thumb:
mark_biddle
Post Fri Jul 15, 2005 12:14 pm
I just had exactly same thing with my car. I don't want to be a doom merchant, but getting the old one out was not just a haynes undo 4 bolts jobbie........... Took me ages and a lot of skin was lost. Hope yours goes a lot better than mine!
Geeman
Post Fri Jul 15, 2005 1:09 pm
Hmm... I replaced mine with no drama. But then I just chucked the whole viscous unit away and replaced it with an electric fan, so no hardship in replacing the 'bad stuff'.
Nizzle
Post Fri Jul 15, 2005 9:49 pm
Well I'll probably be leaving the work to an expert so my skin will remain intact! Thanks for the replies :)
Post Fri Jul 15, 2005 10:19 pm
Nizzle wrote:Well I'll probably be leaving the work to an expert so my skin will remain intact! Thanks for the replies :)
You have much more faith in garage "experts" (including some main dealers) than I have.
No doubt there are some excellant mechanics out there, but very few of them seem to have worked on the E30s that come my way.
TOURINGDADDY
Post Fri Jul 15, 2005 10:28 pm
make sure that they bleed it properly these can b a night mare some times
Nizzle
Post Sun Jul 17, 2005 9:25 pm
Ta for the tip Torunigdaddy.
Brianmoooore,
I don't think I have cause to worry there... I'm in Gloucester and there is a BMW specialist that has been dealing with the car for the last two years - I trust them with my motor.
