318i - 325i
doyley123
Ive got a 325i engine which im going to be putting in my 318i, so i am wanting to know if there is anything in particular i need to know or do for this conversion? Cheers Chris.
leeparkes
have you used a donor car or just got the engine?
doyley123
Ive bought everything i need for the conversion. Just really wanting to know how hard or easy a job it is!
leeparkes
one of the easiest conversions to do,its virtually plug and play!
when you say you have everything do you have the suspension off the 325i,and the diff?
small case diffs dont like b25 power much.
doyley123
Ive basically got everything to make the engine run ie engine, box, ecu, loom, propshft etc. So everything else will be staying 318i till ive got the money to upgrade everything. Looks like an lsd is nxt on the list then.
