Please can anybody advise me best way to clear air lock on a 325i covertible 1988 cooling system. Tried valve on thremo housing. Tried removing header tank pipe(small) to bleed but no luck. Have read to take both top and bottom hose's off. Refit bottom hose,fill engine block through top hose untill visable then fill radiator, reconnect. Start up, heater on Hot+ blower on full set to 2000 rpm, take for a mile run come back release bleed screw on thermo housing and fill up up exspansion bottle....??
Many Thanks Humpo.
Air lock in cooling System on 325i Cab 1988
jay528ise1985
I've just done a coolant change and found raising the front of the car a help in releasing some more air.
1989 BMW 320i 2.7 2 door saloon
this post - might help
try removing heater top hose - did the trick for me
http://www.e30zone.net/modules.php?name ... 2&start=25
Le Mans Classic 2006
