tappety engine
a lot of us have had the same sort of symptoms, normally turns out ot be an exhaust manifold crack. make sure you give it a good checking over..
does it happen when cold/warm/both?
1990 brilliant red 318 is
Bob_S
this is not a poverish m42 mate this is a properish engine with nearly enough valves.asmith88 wrote:a lot of us have had the same sort of symptoms, normally turns out ot be an exhaust manifold crack. make sure you give it a good checking over..
325's tap. they are adjustable.
Now can we all pay attention to the zone wiki waffle waffle
click here---
http://www.e30zone.net/e30zonewiki/inde ... M20_engine
Bollocks to this 24v scrap!
i'll check tomorow for manifold leak. the car starts no problems sounds of noisey tappets and still whilst drivin and wen engine is warm.
hasnt been driven for a year just started here and ther. so wen its got mot might give it a full service may cure it
Bob_S
the manifold is 98% fine mate he has no idea what he's on about and has seen a few posts about 318is owners having a tappy engine, thus every tap is now a cracked manifold.
Bob_S
Yeah, they can be adjusted here is the guide on how to do it. It's very easy to do yourself.
The mani might leak, but I have never heard of a cracked mani on a 325 and it's certainly not worth trying to change the gaskit just in case as the studs are prone to snapping
here is a link on how to adjust the tappets
injectors can tick quite loud too, rev it up a bit then kill the ignition whilst the revs are up at about 4k, if the noise you are on about stops before the engine stops turning then it's the injectors
Bob_S
With regards to killing the ignition do you find a pistol is enough or is a 12 bore shotgun more apt?E30BeemerLad wrote:injectors can tick quite loud too, rev it up a bit then kill the ignition whilst the revs are up at about 4k, if the noise you are on about stops before the engine stops turning then it's the injectors
I prefer leaving the coolant and oil out
yeah, I've found Granville 20/20 is lighter than ATF fluid
thanks for link. seems easy enough. i'll try it and keep you updated. thanks guys for all help.Bob_S wrote:Yeah, they can be adjusted here is the guide on how to do it. It's very easy to do yourself.
valve lifters, rocker arms, tappets, whatever u want to call them need periodic adjustment. the wee eccentric lobes should be adjusted to 0.30mm with the engine stone cold. id get this done ASAP as when i bought mine it was well overdue and i ended up breaking 2 rocker arms which is a pain in the backside to replace unless they are on the #6 cylinder in the back, all otehrs are a pain in the rear. i took the liberty of changing all 12 as i broke the ones for the #1 cylinder.
WMMotorsports
