Hi again,
I forgot to mention this in my other post but my Driver Foglight is not working and I have checked the fuse, relay, connectors and all are fine. Oh and the bulb is ok also.
The left is working perfectly.
Any ideas
Fog Light Help
rowemeister
check there is 12volts @ the connector m8. If not trace the fault back down the wire. If there is 12V then the connector on the light unit has a problem.
325i Sport with Hartge H27 lump
Light needs an earth, as well as 12V+.
