service parts and more...
Looking for genuine BMW parts at discounted prices? Try here!
lloydp
Post Tue Mar 03, 2009 1:57 pm
I’m in need of a whole bunch of parts for my ’93 L-reg 316i Touring”¦ part numbers should be right”¦
Service ”˜kit’ for M40, which I believe includes:
Air filter, oil filter, fuel filter, spark plugs
Out of curiosity, what type are the spark plugs?
I will also be in need of some appropriate coolant (assuming you can post/courier liquids), preferrably enough to fill the system twice so I have some extra until I find the leak.
Replacement parts to fix the rear window wash spray
Protective bit 12141306988
Valve 61661380464
4.6mm hose 61661357388
7mm hose 61671388366
Other bits
Front wheel hub w/bearing 31211131297
Latch striker for boot bin door 51471947370
Grey locking buttons for boot trim 51711947438
M6 stop buffer for tailgate 51241947883
Gasket ring for sump plug 07119963151
Cheers!
-Lloyd
Cotswoldbmw
Post Tue Mar 03, 2009 2:20 pm
Hi LLoyd
i am just about to start your parts list
BMW no longer do a service kit you have to buy individual items so just wanted to check you want complete service items also you can get NGK or Bosch plugs let me know which you would like me to quote on
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
lloydp
Post Tue Mar 03, 2009 2:53 pm
Hi Brett,
The service ”˜kit’ bits are for doing an oil service which is due, so I’m going to say the whole lot is wanted. Is it normal to change the fuel filter as well? I wasn’t planning to, but as I saw it was listed in the ”˜kit’ I thought I might as well.
I don’t have a personal preference on plugs, but as I’ve seen NGK suggested more often than not, we’ll have those, please.
Cheers,
-Lloyd
Cotswoldbmw
Post Wed Mar 04, 2009 8:23 am
Lloyd
I have spoken to our service dept and the oil service is only oil filter and screen wash change, do you want me to quote you on this or complete service items
Brett
Cotswold BMW Parts
01242 335365
lloydp
Post Wed Mar 04, 2009 11:43 am
Brett,
Quote for everything apart from the fuel filter. I'm going to do the rest as well anyway, and otherwise I can just save them for next time!
Cheers,
-Lloyd
Cotswoldbmw
Post Wed Mar 04, 2009 1:50 pm
Hi Lloyd
Protective bit 12141306988 £5.28
Valve 61661380464 £4.20
4.6mm hose 61661357388£2.90
7mm hose 61671388366 £1.00
Front wheel hub w/bearing 31211131297£107.11 + hub nut £2.84
Latch striker for boot bin door 51471947370 £1.63
Grey locking buttons for boot trim 51711947438 £0.32 each
M6 stop buffer for tailgate 51241947883 £1.54 each
Gasket ring for sump plug 07119963151 COMES WITH FILTER
oil filter£7.64
air filter £17.04
spark plugs£27.17 for 4
coolant £24.63 for 4 bottles
Prices inc. VAT delivered to mainland UK
Please call us on 01242 257999 and quote 40203
Brett
Cotswold BMW Parts
01242 335365
