temp guage problem
My temp guage is no longer reading, it will move when I turn the ignition on to just under the White line under cold. I have pulled the display out and checked the nutt and cabels. What else could it be? Also the car is now very rough when cold.
Felix79 aka Dan
E85 Z4M Roadster
E85 Z4M Roadster
- Brianmoooore
If this is a M20, check out the plug/socket (and under the rubber boots) under the inlet manifold, where the injector loom connects to the engine loom
