This wheel offset thing
Turbo-Brown
- Boost Junkie
Is it just my car (of 1985 vintage) or are all E30s barring the 'ix' supposed to have an offset of 35mm?
I keep seeing people quote 25mm which must've come from somewhere, but my old steelies have 4 1/2J14ET35 stamped on them and the handbook also states that all cars have a 35m offset.
I'm confused and my head hurts!
Can anyone clear this up for me?
Cheers!
Cheers!
nav786
its the bbs wheels that have offset of 24 0r 25. (not sure which). steelies re 35.
FOR SALE
SONY PSP'S £100
Ziggy
Bottletops and steelies are indeed 35mm, but BBS are 24...
Looks better with em further out in the arches & wider wheels would have clearance issues on 35mm
HTH!
HTH!
Turbo-Brown
- Boost Junkie
Well, you say that, but my 7x17" wheels have an offset of 35mm and don't appear to be about to foul anything (not that I've tried yet).
How odd!
How odd!
Ziggy
Ah well!
It is only 10mm we're talkin about here... & a wider track would potentially improve handling too... if you could even notice the difference!
i think they will rub mate, u would need quality hub eccentric rings from say H&R with just 4x100 holes in them, proper longer bolts too! this is important as i've seen a wheel fall off with spacers and normal bolts!!!!
hartge 16x7.5 are et25 and it's a nats cock between the chock and wheel
same with alpinas 16x7 et28
my 2p as u are a turbo guru!
Actually i'm sure Ian 332 has 17x7 bbs wheels with et35 and he has 10mm spacers! and very large porker brakes at the front!!
HTH
HTH
Turbo-Brown
- Boost Junkie
Ah haaa!
Just been thumbing through my "things to do on the cars" book and found this web address which explains it!
Looks like the more +ve offset you have, the more wheelarch clearance you get but the closer to the struts etc. the rim & tyre get:
Ziggy
Erm yeah... could have told you that!Turbo-Brown wrote: Looks like the more +ve offset you have, the more wheelarch clearance you get but the closer to the struts etc. the rim & tyre get:
More offset = more distance from wheel centre to hub = smaller track.
Less offset = less distance from wheel centre to hub = wider track.
With the associated clearance issues you'd expect from either!
& you only get negative offsets on 4x4s really, so no need to worry about that.
Turbo-Brown
- Boost Junkie
Ziggy
More clearance to the arches, but less to the struts...Turbo-Brown wrote:fair enough. It's just I couldn't understand why people were saying I'd get rubbing with 7J17 rims and a 35mm offset when infact there should be more clearance
timbob
bringing an old thread back to life,
hi, one of my mates has just bought an e30 320i 2dr and wants to buy some 18's for it, what offset should he be looking for?
cheers, tim
cheers, tim
Ziggy
Welcome to the zonetimbob wrote:bringing an old thread back to life,
cheers, tim
timbob
thanx for the welcome and the reply dude, very helpful
- Homo Hair
i was running 205 tyres on 7" rims with an offset of 37mm with not rubbing on the strut..
