Setting up the on board computer time/date/range etc
DougieN13
Sat Feb 28, 2009 11:20 am
I had to take my battery off the other day and when i reattached it all the settings on the on board computer on the dash reset (time, date etc) and the range changed to km instead of miles
How do i set it all up?
tomtomiS
Sat Feb 28, 2009 11:24 am
ignition on, press the little button on bottom right hand side with a ballpoint pent or similar. select the different function ie time/ date and set with the row of numbered buttons on the bottom. to set km instead of miles press the consumption button and then press the setting button on bottom right with afforementioned ballpoint until you get the km's
DougieN13
Sat Feb 28, 2009 11:32 am
tomtomiS wrote:ignition on, press the little button on bottom right hand side with a ballpoint pent or similar. select the different function ie time/ date and set with the row of numbered buttons on the bottom. to set km instead of miles press the consumption button and then press the setting button on bottom right with afforementioned ballpoint until you get the km's
Cheers man, il give it a go, i never noticed the small reset buttons before.
