front wheel bearings
alpinachris2
i have some exchange struts to go on a sport what i need to know is can i transfere my wheel bearings over to the exchange struts ? the bearings are the abs ones and quite expensive to buy i know as both are new
smithy318i
Once fitted to a car, you cant remove them.
well not exactly, removing them breaks them, and the useful life is drasticly short.
Im sure that'n NOT what you wanted to hear, but....
alpinachris2
yeh cheers i thuoght so typical aint it
That's the official line, but it depends how much they fight back when you try to remove them.smithy318i wrote:Once fitted to a car, you cant remove them.
If the good bearings are attached to scrap struts, then it's worth a try. I have struck lucky before.
Swop the retaining nuts from side to side and unless you are unlucky, you'll be able to stake them again. (B.Moore, proprietor,Skinflint engineering)
smithy318i
love it.!(B.Moore, proprietor,Skinflint engineering)
alpinachris2
thanks brian ill give it a go not got much to loose really ,only about Ԛ£100 bucks ,lol
