Correct Offset for 7.5x17??
Mikey_Boy
Mon Feb 23, 2009 10:18 am
Hello folks,
A quick one and apologies if this has been asked a 1000 times before. Have an 89 325 sport currently running 15s with ET24.
Looking to get 17s (AZEV A's for that old skool look) that are 7.5 instead of 7 inches wide, running 205/40x17 tyres.
Can someone please advise on the correct offset - was thinking ET25 to keep things as close to standard as possible, but don't want the wheels fouling arches etc etc.
Any advice would be great!
Cheers,
Mikey_Boy
georob
Mon Feb 23, 2009 10:42 am
I'm running 7.5 x 17 on et25 with no issues...lowered 60mm
E34 x 1 - V8 + lots of CF
E30 x 2 - Tourings (1 x M50, 1 x M40)
RS6 C5 - Stage 1 remap - 500bhp
George
Ziggy
Mon Feb 23, 2009 10:56 am
The 17x7.5 Azev As come in ET20 IIRC - plenty of people use those with no problems. :thumb:
They're also available in a FWD offset which would require lots of spacing & be far from ideal - just make sure you get the right ones!
As an example, although it was with 16" wheels, Hartge used 7.5" rims in both ET20 and ET25.
Mikey_Boy
Mon Feb 23, 2009 12:48 pm
Thank you for the advice!!
Mikey_Boy
Mon Feb 23, 2009 9:26 pm
205/40 is the wrong size by the way.. 215/40 is proper :)
thomasm30
Wed Feb 25, 2009 12:02 pm
Hi. You can all so use the offset ET30 with on problems. :)
I`m running 7.5 x 18 on ET30 with on problems.
