318i M10 Speedo not working....
miniblob
Fri Feb 20, 2009 3:28 pm
Right then, what do i look for???
I could do with having the speedo working, due to the amount of speed cameras i drive through going to/from work!!
Is it likely to be the instrument cluster? (everything else works)
Is there a connection on the autobox i should check??
Any other causes???
327 Touring with bass!!!
Ralphead
Sun Feb 22, 2009 4:46 pm
The speedo in my 316i is temperamental, I'm pretty sure its the connector onto the back of the instruments as a sharp slap on the dashboard brings it back to life. I'm just too lazy to pull it all apart to have a look yet.
Sun Feb 22, 2009 5:21 pm
90% of speedo not working faults are as a result of an internal break in the wire leading to the sensor on the diff, caused by vibration.
The remaining 10% are mainly caused by a duff sensor in the diff, or by cracked solder joints on the speedo unit inside the cluster.
Sun Feb 22, 2009 5:30 pm
Brian.. In your experience, how much loom needs replacing when the wire is broken?
Sun Feb 22, 2009 7:26 pm
Change the last foot, and you'll be sure.
Get a piece of wire, complete with plug, from the headlamps of a scrap E30, or, IIRC, a repair lead is available from BMW.
Gwynleym10
Sun Feb 22, 2009 9:35 pm
Check the fuses as well...
My old m10 had a duff speedo - turned out to be the fuse!
Dual wheel carriers -------195litre Fuel Tank
London 2 Cape Town
www.Overlandinthesun.com
miniblob
Tue Mar 03, 2009 9:45 am
Just dragging this one up again now the car drives straight!!!
I reckon a fuse would be far too easy - any idea which one?? Surely it would affect other stuff too though??
Am i right in assuming you mean the break is most likely under the car near the diff?? If so, i'll crawl under and change it for a headlamp wire!!!
Looks like the scrap on my drive is finally coming in usefull!!
miniblob
Fri Mar 06, 2009 9:24 am
Ok, have had a little poke about under the car - although i haven't replaced the cable, i did wiggle it about and reseat the connector. There was no corrosion on the plug and the cable looked ok, but obviously i wouldn't see if it was breaking down under the insulation.
I have realised that the mile meter is still working and ticking over as i drive!!! Would this indicate the cable is ok?? Surely it must use the same signal/connection??
Everything works fine except the speedo - am i really gonna have to crawl about on the floor to replace this cable, or would it more likely be something breaking down in the dash cluster??
Fri Mar 06, 2009 6:48 pm
If the odometer is still working, then the problem is on the speedo unit itself!
miniblob
Fri Mar 06, 2009 8:13 pm
Coolio - saves crawling around to change that cable - would be a piece of cake on ramps, but on the kerb it's just a pita!!
Will swap the unit tomorrow morning (if i'm not too hungover!!) and see what happens!!
MrAsp
Sat Mar 07, 2009 12:10 am
In my '84 320i the speedo works only when it wants.
I noticed that it works properly when the cluster is hot (when the car is exposed to the sun, during summer for example), and sometimes for a few moments when the car is very cold. :?
The odometer does the same.
I think the wiring is ok...
Maybe the SI batteries? :?:
55 litres of BluSuper: approx. 80€
A set of Avon "ZV3" : approx. 260€
Feel your car cornering with gas: Priceless!!
