Prices for the following please:
1991 325i SE - 4 dr
34341111435 - DISTRIBUTION PIECE M10X1 and bolt
34341163565 - brake pipe clips x 6
33321128417 - REINFORCEMENT x 2
3311129676 - INNER HEX BOLT x 4
34521155041 - PULSE GENERATOR (rear ABS line)
33172228425 - Z3M diff bush
33531136387 - rear spring pad 10mm x 2
51461905393 - rear blind bracket x 2
handbrake cable - passenger side
65711385084 - CLUTCH SWITCH BRACKET
34359058889 - BRAKE PAD WEAR SENSOR x 2
6131176747 - PLASTIC NUT x 6
7119901299 - HEX HEAD SCREW x 5
34111123072 - INNER HEX BOLT x2
26121226723 - CENTER MOUNT
26121225071 - GROOVED BALL BEARING
few parts
Brenner5
320_Fizz_i
Cotswoldbmw
Hi there
34341111435 - DISTRIBUTION PIECE M10X1 and bolt £4.60
34341163565 - brake pipe clips x 6 £.055 each
33321128417 - REINFORCEMENT x 2 £0.77each
3311129676 - INNER HEX BOLT x 4 Digit missing
34521155041 - PULSE GENERATOR (rear ABS line)£92.64
33172228425 - Z3M diff bush £22.33
33531136387 - rear spring pad 10mm x 2£4.14
handbrake cable - passenger side £19.63
65711385084 - CLUTCH SWITCH BRACKET£4.90
34359058889 - BRAKE PAD WEAR SENSOR x 2 £6.31
6131176747 - PLASTIC NUT x 6 Digit missing
7119901299 - HEX HEAD SCREW x 5 £0.15each
34111123072 - INNER HEX BOLT x2 ££0.72each
26121226723 - CENTER MOUNT £50.40
26121225071 - GROOVED BALL BEARING£14.96
Prices inc. VAT delivered to mainland UK
Please call us on 01242 257999 and quote 38891
Brett
Brett
Cotswold BMW Parts
01242 335365
PayPal? - No Problem
Just send the amount quoted as a gift to partscheltenham@cotswoldgroup.com, along with your name, reference number, delivery address and contact telephone number.
01242 335365
Brenner5
Hi,
Sorry,
Can you quote on these too please? (missing digits included)
63121378369 - BLACK RUBBER BUSHING x4
33311129676 - INNER HEX BOLT x 4
16131176747 - PLASTIC NUT x 6
51461905393 - rear blind bracket x 2 - do you have any type of brackets to hold the rear blind? i need the clips on the roof side
65711385084 - CLUTCH SWITCH BRACKET£4.90 - is this correct for the brake/clutch cut off for cruise control- i heard they were NLA?
Sorry,
320_Fizz_i
Brenner5
Prices on these 2 as well please;
SHAFT SEAL - 23121205340
SHAFT SEAL - 23121282394
320_Fizz_i
Cotswoldbmw
Afternoon
340 £9.00
394 £5.90
Ref No 38891
Prices include vat,discount and delivery
Regards
Karl
340 £9.00
394 £5.90
Ref No 38891
Regards
Karl
Cotswold BMW Parts
01242 335365
01242 335365
Brenner5
Thanks,
Can you quote on these as well please?
I'll be ringing today
320_Fizz_i
Cotswoldbmw
Afternoon
369 x4 £5.97
676 x4 £2.09
747 x6 £1.75
393 X2 £3.34 We dont keep any of the clips in stock sorry
Thebracket is correct
Ref No 38891
Regards Karl
369 x4 £5.97
676 x4 £2.09
747 x6 £1.75
Ref No 38891
Regards Karl
Cotswold BMW Parts
01242 335365
01242 335365
Brenner5
I'll take these;
33321128417 - REINFORCEMENT x 2 £0.77each - £1.54
33311129676 - INNER HEX BOLT x 4 £2.09
33531136387 - rear spring pad 10mm x 2 £4.14
16131176747 - PLASTIC NUT x 6 £1.75
63121378369 - BLACK RUBBER BUSHING x4 £5.97
65711385084 - CLUTCH SWITCH BRACKET £4.90
7119901299 - HEX HEAD SCREW x 5 £0.15each 75p
34111123072 - INNER HEX BOLT x2 ££0.72each £1.44
SHAFT SEAL ”“ 23121205340 £9.00
SHAFT SEAL ”“ 23121282394 £5.90
Can you get these in stock?
51461905393 - rear blind bracket x 2 - £3.34
I'll be ringing soon..
thanks for all your help
320_Fizz_i
