Pic Request, repaired jacking points/welded footwells
SteSE
- Heading for the Naughty Room
I need to have both jacking pads on my E30 replaced. The drivers side has gone and a small hole has appeared behind the accelerator pedal (see pic below). The passenger side is starting to go too although hasn't yet rusted through to the foot wells. Just need some pic's of how other people have addressed this problem.
jbh
- Hartge Crew
I was tempted to cut the sections out a another shell I've got but would be a shame as its rot free. its just a pity its a 4 door
SteSE
That's a good idea i'd not thought of.
cro320
my passenger side is pretty weak, I am going to get that sorted at my bodyshop
E30_Aza
my old man did my jacking point, the seal and patched in a rather large rusted hole behind my glove box early last year. sorry i aint got any pics at hand but the jacking point is easy to fabricate with some decent gauge steel and a good welder. as for rusty bits, cut out as much as you can. when i had them bits welded up i then sealed every inch with a body sealant, then used a high zinc etch primer over the top, then a thick layer of por15 (from frosts) which is a rust proventer. dries a bit like powder coating, very hard material. hope this is some help. not saying its the best help but has not given me any grief so far (touch wood)
genuine chromie rust, not often you see that
no after shots, got my uncles mate to do welding, he did that MOT and Blead the brakes for £100 which i thought was v good
after he put some of that black stuff over to make it look factory ish
at least my IS is like new there
spook
- League two here we come !!!
That small hole turned into this
one sunroof panel later
