m30 idle problem ?? help
blingsta
Boost Junkie
Post Thu Jan 29, 2009 4:31 pm
Guys, i was led to believe that the ecu and tps i had running my 3.5 were actually from a 2.5.. so i got hold of a 3.5 ecu and tps.. bolted them on and adjusted tps.. car now idles fine, but as soon as i drive away and in between gear changes if i leave my foot on the clutch for long inuff, the revs stay at 1500 rpm's, if i stop at lights, it takes about 10secs for it to drop down to normal.. why is this?
zaust
Zone day release
Post Thu Jan 29, 2009 4:39 pm
Sticky tps.
Possible afm missmatch too.
Does it go better btw ??
M30 Tech 1 Touring on gas.
blingsta
Boost Junkie
Post Thu Jan 29, 2009 4:43 pm
no difference fella.. but benefit of the doubt, its not set up properly!! as for the AFM, its only the 3.5 ones that are upside down anyway, so dont think theres any issues there!.. TPS seems clean and clicks away without issues
zaust
Zone day release
Post Thu Jan 29, 2009 6:34 pm
Ecu still learning or a small air leak is possible too.
