have 325i sport had new rotor arm , new plugs infact had a dam good servive about 2k ago , the problem i have is last week it kept pulling back if i was doing about 60mph, as soon as you boot it it would be ok , then when cruising , would play up again..
how ever this week this little episode has stopped ..
the other day when it was ticking over , i went to put my foot down , and nothing just spitting couldnt even pull off . so switched it off , then same again , swiched off agin , then it was fine , been good eversince , infact today it has driven brilliantly .
would iffy ht leads sometimes play up ?, cars 20yrs old 105k, , probably never been changed.. car only does 3k tops a year , but gets serviced every year, its well spoilt , apart from the leads , what else could it be ?
thanks in advance
pulling back
