M52TU identification
Soundstorm
Post Sat Jan 10, 2009 1:33 pm
Hi,
I have read numerous amounts of info about the M50/M52, but now I'm in doubt of myself.
If the engine is an M52 with double Vanos. Does that automaticly mean that it's a M52TU?
I want an aluminum block with steel liners. And I thought that was the change in the TU, together with double Vanos.
Am I right? Or are there double Vanos blocks with nicasil coating as well?
Greets
BadDave
Post Sat Jan 10, 2009 5:46 pm
The double vanos ones are the TU(technical update) ones afaik
Mines an alloy blocked one (M52B28). with IIRC an Alusil coating.
They also have bolted on,stiffening brackets for the main bearing caps as well.
Post Sat Jan 10, 2009 7:28 pm
Yes the double Vanos alloy block 24v is the M52TU.
Post Sat Jan 10, 2009 10:38 pm
BadDave wrote: They also have bolted on,stiffening brackets for the main bearing caps as well.
Same as all the alloy blocks
