Intermittent Brake Light flashing
TheMonzta
Sat Jan 03, 2009 3:17 pm
I noticed last night that my wife's 318i's brake lights are flickering on and off as she drives along almost like she's tapping her brake pedal intermittently.....which of course she isn't.
What could be causing this? As it affects both brake lights together I'm guessing it's not a loose connection in one particular light cluster. Is there a switch mounted near the brake pedal that could need adjustment or replacing? :?
1991 Honda Civic Twin Cam
1996 VW Golf TDi
2001 BMW 540i Sport
Awaiting the next E30
konfuzion
Sat Jan 03, 2009 3:19 pm
Yup, one just above the brake pedal. Had to replace this on my previous touring. Was ~£8 new IIRC.
Regards,
Ian
Kingdoms are run by Kings, Dictatorships are run by Dictators, England must be a Country.
**BANNED**
Sat Jan 03, 2009 3:25 pm
May just be a loose switch or connector,worth a check before spending any hard earned.
Youth is wasted on the young.
TheMonzta
Sat Jan 03, 2009 3:26 pm
konfuzion wrote:Yup, one just above the brake pedal. Had to replace this on my previous touring. Was ~£8 new IIRC.
Regards,
Ian
Cheers Ian. Was it a strightforward job? Just unbolt old and refit new one?
1996 VW Golf TDi
2001 BMW 540i Sport
TheMonzta
Sat Jan 03, 2009 3:28 pm
daimlerman wrote:May just be a loose switch or connector,worth a check before spending any hard earned.
Yes, I'll take a look at the switch and see if it's something I can fix before ordering a replacement.
1996 VW Golf TDi
2001 BMW 540i Sport
konfuzion
Sat Jan 03, 2009 5:09 pm
TheMonzta wrote:Cheers Ian. Was it a strightforward job? Just unbolt old and refit new one?
IIRC, it's a push fit with a couple of plastic tabs. The swicth itself was rectangular, a bit like a small 9v battery.
Not the easiest of things to get to, but the process is easy enough :)
Regards,
Ian
