hey guys ...did anyone here ever fitted a m tech 2 kit to a cabrio ? i am having dificulties with fitting the outer panles and side skirts ,can't locate the drilling jigs for the skirts on realoem or bmwfans.info ,and the guys at my local dealership said it doesn't need drilling ,although i'm 99% sure they don't know what they are talking about, because the car doesn't have any holes on the beneath the door , and the plastic m tech skirt clearly fits by clamps inserted in holes drilled in the bodywork .....so , any ideea ?
http://bmwfans.info/original/E30/Cab...1/ill-51_2002/
m technic 2 on cabrio
- E30 Zone Meets/Events Team
Firstly, have you got the right kit, as the sills for the cabs are deeper because of the "GIRDERS" on the sides of the cab.
They do need to be drilled for the clips.
If you've got a normal kit, they will be difficult to fit.
Everything else should go on no prob.
HTH
HTH
mrLEE30
as above the tech 2 kits for cabs are specific for the cab, and secondly i assume you have the ''facelift'' cab??
otherwise all including a link to the side skirts are here
http://www.e30zone.net/e30zonewiki/inde ... ar_bumpers
mrlee
mrlee
ionusunt
yes is the right kit with the deep sills . thanx for the answer.
about the drilling , do you know if i can use the normal 2/4 door drilling jig ?
FormerMember
You don't need to drill the doors. All you need to drill is the side skirts (~20 holes / side), and those are on different places than in 2/4 door.
I drilled my holes without any jigs, went without problems (you can use the side-list holes for locating new holes). You'll get it when you play with the parts for a while
E30 Cabrio M-Tech, powered by V8
E34 M5 3.8 x 2
Alpina D10 Touring #33/93
E46 318i Touring
Toyota Hiace 4wd
E34 M5 3.8 x 2
E46 318i Touring
Toyota Hiace 4wd
ionusunt
this is what i tried to figure out today , where the holes should be by placing the mtech side skirt on the body's skirt ...hope they will fit straight on....
chris_m50
Hey guys I have just broken my sport and i am saving up for a cabby. I have taken the kit off and am hoping to fit it to the cabby..
Has anyone got skirts for a cabby?? or as I hear they can be 'modified to fit'
Any help would be great
thanks
Chris
thanks
Chris
