I'm going to have a go at changing the cambelt on my 325 next week and am ordering the bits now.
So far on the shopping list I have:
Cambelt
Waterpump (assume this comes with gasket?)
Tensioner
Distributor cap
Rotor arm
Spark plugs
Power steering belt
The only bit I'm stuck with is that I can't find the alternator belt on the GSF website. Am I being thick? Please help!
Alternator belt - can't find on GSF
march109
- Contact:
There are three belts, they call it the fan belt.
march109
- Contact:
Yes.klu99apm wrote: Waterpump (assume this comes with gasket?)
oil filter, air filter, fuel filer, oil, coolant, and PAS fluid are all a good idea too if you haven't thought about them already.
march109
- Contact:
B13010 TIMING BELT-ROUND TEETH E30 320i / 323i / 325i M20 Eng. 9/82>1/93 Round Profile. 127 Teeth 7.90 Add
B13100 TIMING BELT TENSIONER E30 320i / 323i / 325i M20 Eng. 9/82>1/93 Round Profile. 127 Teeth 13.50
13336 POWER STEER.BELT-10x825 E30 325i 85>92 M20 2.50
13343 FAN BELT-10x965 E30 325i 85>92 M20 3.00
B17017 WATER PUMP-BQ E30 325i 88>91 M20 26.40
MMW719/15 OIL FILTER-GER(SCREW ON) E30 325i M20 09/83 > 06/91 3.30
MMC26110/1 AIR FILTER-BQ E30 325i M20 09/83 > 06/91 BQ 6.25
Open the box to check ! I bought my water pump from GSF, asked if it came with a gasket and the guy said yes, so I checked and it wasn't in there. Lucky I did cos I live quite a long way away, the trip back to pick up the gasket would have been inconvenient to say the least....march109 wrote:Yes.klu99apm wrote: Waterpump (assume this comes with gasket?)
