Noise from engine on start up
billyboy193
Post Thu Jun 30, 2005 12:13 pm
Got a 325i that upon starting and driving hard (not thrashing it) there is a clattery sound, sounds like a tensioner on the chain or the chain rattling against something could it be anything else? but when you have driven it a few hundred metres it has gone and you don,t hear it anymore!
koos
Post Thu Jun 30, 2005 12:21 pm
As far as I know it doesnt have a chain, it has a cambelt. If it rattles at startup and goes away then it probably needs the valves adjusting. would benfit from a oil change aswell or in extreme cases there is low oil pressure and the oil takes a while to get to the top.probably tappetts though. check the oil level aswel.
Treeman612
Post Thu Jun 30, 2005 12:40 pm
2.5 engine uses cam belt, not chain. The only rattles you would hear from cam belt end would be if the tensioner has disintergrated - this would not go away, and would mean you are about to lose the cam belt (uh-oh!)
Has the cam belt been changed? - if you're not sure, my advice is get it changed ASAP, and replace the tensioner at the same time.
billyboy193
Post Fri Jul 01, 2005 9:25 am
Oil pressure is ok and level is ok and just been serviced and has fsh but unsure when belt was last done may get it checked out just in case - cheers
